Toyota landcruiser fj40 polyurethane gas tank - $100
This tank is designed to be a direct replacement for the 3/1973 thru 12/1978 FJ40 Land Cruiser. It will fit with minor adjustmentsin 2/73 and down, most notable the filler neck
100% polyethylene OEM gas tank replica replacement. This tank is cheap, darn near indestructible and it'll drop in without hassle.
Features:
• Nearly 1/4" thick Polyethylene for incredible strength
• Sending unit
• One-piece construction (no welds or seams to fail)
• Never, ever will it rust (thank god!)
• Will always stay pliable, even at 100 degrees below zero
• Installs in a snap
• Uses all OEM equipment (including the sending unit)
• Fuel pickup tube is located on top of the tank
• No more clogged fuel systems from rust or deteriorating sprayed liners
• Affordable!
• Sending unit
OEM replica replacement gas tank that would never rust, fit using original hardware, has no welds or seams to fail and wouldn't crack or become brittle, even at 100 degrees below zero!
Are you thinking what I'm thinking?
