» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 02-20-2008, 11:11 AM   #2 (permalink)
JAXTOY
JAXTOY's Avatar
Member Number: 11799
Re: Looks like my Transmission Leaking (thoughts?)
Looks to be your rear main seal, I think you are seeing engine oil not trans fluid. Clean the areas where you have oil, then drive it and check again. If it is trans oil it will be a reddish color, engine oil will be dark. The auto trans is checked by pulling the fill plug, then use your finger to check the fluid level. Could also be your oil pan is leaking around the gasket. This happened all the time in my FJ 62.
JAXTOY is offline   Reply With Quote
