Re: Looks like my Transmission Leaking (thoughts?)
JAXTOY previously said:
Looks to be your rear main seal, I think you are seeing engine oil not trans fluid. Clean the areas where you have oil, then drive it and check again. If it is trans oil it will be a reddish color, engine oil will be dark. The auto trans is checked by pulling the fill plug, then use your finger to check the fluid level. Could also be your oil pan is leaking around the gasket. This happened all the time in my FJ 62.
Thanks for the input. I am going to check it after driving home from work today.
And where is the fill plug for the Trans.? Thanks
Voodoo Blue 4x4, All Pro FWB, OME lift, TRD CAI, Pro Comp Xtreem muds 285/70/17, Uniden PC 78 Elite w/ 4' firestick, MAN-A-FRE engine skid, Scuba Driver, Safari snorkel
