06-04-2006, 04:10 PM
#1
Member Number: 2261
New CB Antena Mount !!!
I made Myself a Heavy Duty steel CB Antenna Mount... THE "Bandi Mount"...
WORKS and LOOKS GREAT !!!
[edit]
Now they Will be more readially available while still have the same quality
and design, Thanks to All-Pro Off-Road, who are now Producing them !!!
For all that are "On The List" , You are still "On the List" !!!...
No worries There !!!... Please See ALL-PRO's Thread HERE !!!...
For More Info on CB Setup for the FJC... See the
BigBill25's Cobra 75 WXST and Bandi Mount Installation...
More Details to Follow !!!
The "Bandi Mount" Now By ALL-PRO OFF-ROAD
Phone:951-658-7077 ~ Fax:951-658-2375 ~ Email
bandi previously said:
THE BELOW IMAGES ARE OF THE ROUGH PROTOTYPE
I MADE BACK IN JUNE, AND DOES NOT REPRESENT
THE FINAL PRODUCT IN QUALITY AND DIMENSION...
Bandi Mount Paint Recomendation
Mask off threaded portion of mount, and for CB Useage, Be
Sure to Mask of the Antenna ground area (See Step 3 below)...
I Used for Primer Coats:
Rustomium Auto Sandable Primer - 2 coats...
And then for Finish Coats:
Rustolium Professional Flat Black - 4 coats...
This will give you a thick Powdercoat "Like" finish...
Bandi Mount Instructions
ITEMS NEEDED:
Masking Tape (or equivalent)
Mid size Flat Head Screwdriver (or equivalent)
7/16" Open-End Wrench
NOTE:
If you intend to install a flag, you can skip steps 3 and 6.
Door position during installation should not be in the fully opened.
The approximate position as shown on Image 5 should be used.
INSTRUCTIONS:
1. Before installing the mount, cover the areas in red on Image 0
with masking tape to protect the FJC's paint during mount
installation. Be sure to fold it over the edges of the body and the
door for maximum protection.
2. First, you need to remove the center plastic hinge cover. This
cover is only snapped on over the hinge. It has two stubs sticking
out that slide into the mounting hole shown on Image 2. From
inside of the opened door, You need to spread the two halves of
the plastic cover and push it outwards.
Image 0
3. For CB Antenna mounting (unless you get a Groundless RV/Marine
type antenna), there must be a ground contact for best TX/RX of
the CB. You will have to remove the paint on the underside of the
mount in the area of contact with the bottom section of the
antenna so that the two pieces make contact to complete the
ground. This area is shown in red on Image 1. This can easily be
achieved with a mid size flat head screwdriver, by scraping away
the paint from inside the red circle area.
4. Install and tighten your CB Antenna Base connector onto the
mount prior to the mount installation on the vehicle. If done at a
later time, you will need a deep socket to hold the underside of
your CB mount to be able to tighten the top part.
Image 1
5. Image 2 shows the location of the mounting hole that is
already on you FJC's Hinge. This will be where the mount bolt
will go through when you place the mount in position.
Image 2
6. As done in step 2, For CB Antenna mounting (unless you get a
Groundless RV/Marine type Antenna), there must be a ground
contact for best TX/RX of the CB. You will have to remove the
paint on the hinge where the stainless steel nut (included in your
package) makes contact with the hinge. This area is shown in red
on Image 4. This also can easily be achieved with a mid size flat
head screwdriver, by scraping away the paint from inside the red
circle area.
7. With the door in position as shown on Image 5, place the mount
through the space as shown on Image 3, and line up the bolt with
the hole in the hinge and slide it through so that the end of the
bolt is flush with the other of the hinge.
Image 3
8. Place the SS-Nut in the 7/16" open end wrench and slide it
over the hole between the door and the hinge. Now press the
mount from the back side and turn the nut to get it started.
Snug up the mount by tightening the SS-Nut, but leaving it
loose enough to adjust the mount to be centered on the hinge.
9. Close the door slowly making sure not to damage the mount
due to being out of alignment with the hinge at this point. Do
this by watching as you close the door for any contact between
the mount and the top and bottom hinge covers.
10. Eye-Up the mount from the side of the FJC and adjust it by
rotating a hair up or down so that the angle matches the top
11. Tighten the SS-Nut so that the mount is stable and will not
rotate out of position. The bolt on the mount looks small, but it
is a grade 8 bolt and is plenty strong enough to hold the mount
in place, and the rough surface coating on the hinge works as a
grip to the mount once you tighten it down.
Image 4
Image 5
Congratulation !!! You just installed your All-Pro "Bandi Mount" !!!
Image 6
Thank you and Enjoy...
Leroy...
[[[[[[[[[ DEMELLO FlatTop Bumpers ]]]]]]]]]
The "Bandi Mount" From ALL-PRO OFF-ROAD
