Old 02-27-2008, 07:56 AM   #5 (permalink)
JoeUser
JoeUser's Avatar
Member Number: 15334
Re: Irwin sockets for rounded-off bolt heads and nuts?
Being in NY, are you sure it wasn't salted roads in the winter time, that caused the corrosion? Doesn't take a lot of salt to start the corrosion process.
Another alternative to the Irwin removers is to drill a hole in the center of the bolt, just deep enough to use and easy-out bit (reverse-threaded bit, that bites into the bolt, facilitatiing the removal of the bolt)...
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
JoeUser is online now   Reply With Quote
