Old 02-27-2008, 07:22 PM   #10
J-Rock!
J-Rock!'s Avatar
Member Number: 9382
Re: Finally! A solution for American Racing Center Caps!
ddibart previously said: View Post
Looks nice with the teflon caps. Hey what size did most of you go with the 17" or 18" and what offset zero or the neg. Im just getting ready to pick out a wheel tire combo, and I will be using a set of spider trax spacers.
I went w/18x9 & -12mm offset since that was the only option available in 18's for the ATX Thug (for an FJ Cruiser). Many ATX-series wheels from AR will require you to either have a lift or use matching oem tire overall diameter due to the crazy offsets (to avoid rubbing when turning). In otherwords if you don't have a lift then you can't use MT/AT tires. Whatever AR wheels you get, make sure to get the part # that ends in 83 since that's the version w/the 108mm hub.
07' GSJ-10 1GR-FE - Blacked out & slightly modded for the streets. The closes thing to offroading I'll ever do is go over a curb...w/my V-rated truck summer tires!
08' E92 S65B40 (M-DCT 7-Speed) - Weekend cruiser...Volk Time Attack & carbon fiber FTW!
J-Rock! is offline   Reply With Quote
