Risky previously said:
Does that mean if i connect the accessory itself direct to the battery but it's reated to 10A and then connect it to the kettle would that be a problem or it will work but it will draw a lot of power?
The accessory itself has a 10A fuse, so would it still be OK if i connect it directly to the fuse box with the wire crimp as i can't find the tap a fuse accessory here (BTW I'm from DUBAI, UAE)
May I know why was it PITA? May i know what the problems you face with the wire crimp?
Thanks.
You need to cut the plastic insulation off of the end a red connector exposing the metal and then squeeze the end of it into a flat-ish shape the will slide into one side of the fuse slot. It is hard to get it the right shape, so it fits snug but not loose.
