Old 03-01-2008, 03:35 PM   #234 (permalink)
Risky
Risky's Avatar
Member Number: 14861
doublejfj previously said: View Post
This means if you connect the kettle that draws 16A to a 10A outlet, you're going to blow the fuse, or if there is no fuse, burn up the wiring (or at least heat it up nice and warm).
I would not tap into the fuse box unless I was using an add-a-circuit. I'd order the add-a-circuit and wait for it if you're having a hard time getting it locally there.
If you connect the accessory directly to the battery, the alligator clamps should be good for up to 20A or so. Many of the small, high-volume air pumps are this way (too much current for the cigarette lighter plug, but alligator clips to clip to the battery).
Unfortunately i tried to order the add-a-circuit from the link provided above on amazon but they don't ship them overseas. Does anyone know of any other site on which i can order them and they ship it to Dubai, U.A.E?
Thanks so much everyone for the input.
Seif M. Tawfik
Dubai, U.A.E
FJ Titanium 2008
Roof Rack
Garmin GPS 276c
Risky is offline   Reply With Quote
