Old 03-12-2008, 11:06 AM   #4 (permalink)
JoeUser
JoeUser's Avatar
Member Number: 15334
Re: Toytec lift woes....
If I remember correctly, the clocking of the coil spring should be such that the end of the spring should be facing the frame (toward the engine).
Double-check to make sure that the sway bar is 1) centered, and 2) not striking the spring and/or lower spring cup during compression (there's not a whole lot of clearance, even when the sway bar is centered)...
With so many successful installations out there, it would seem that the problem may be installation-related...
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Toytec 1" diff drop kit (as soon as I get around to spacing the skids); Metal Tech step sliders; Mini-Me OEM roof rack; fender-mounted disruptors
JoeUser is offline   Reply With Quote
