Re: Toytec lift woes....
Are you sure the UCA is coming in contact with the coil spring? Do you see paint coming off either component where they come in contact? I would also double check to make sure everything is tight. There was a case not too long ago where the shop forgot to tighten the two big bolts at the lower control arm/ball joint.
400 tons @ 80mph = not so good stopping distance.
