Old 03-12-2008, 01:56 PM   #10 (permalink)
Garsgrl
Garsgrl's Avatar
Member Number: 3187
Re: Toytec lift woes....
Are you using the 0.5 in toytec spacer? With the OME lift the front struts are 0.5in longer then the stock struts. So, the spacer isn't needed. However, u can install the 5mm or 10mm trim packer if needed. Maybe the spacer is the prob.
Garsgrl is offline   Reply With Quote
