Re: Front brake job
akoda previously said:
Yes, you can replace the pads only without removing the calipers. I did it on my 05 Runner that has the same breaks as my fj. I haven't had to replace them on my fj yet.
Yeah, you can do that. But I prefer to put a set of turned rotors on with the new pads. I find there is no "break-in" period for them to match up, and the pads last longer when you start with a nice flat surface on turned rotors. So typically I buy an extra set of rotors and pads to keep on the shelf in the shop. Then when I hear the dreaded "brakes need changing" noise, I just have to do the routine..
I think that brakes are pretty important and worth a few bucks..
07 Titanium loaded..
Current mods: scuba breathers, OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
