Old 03-20-2008, 05:43 PM   #216 (permalink)
bartt
bartt's Avatar
Member Number: 1660
Re: Cobra 75 WXST and Bandi Mount Install
doublejfj previously said: View Post
Check your ground first, then try a 4 footer or higher. That'd be my guess based on my experience with the metal junk up top.
Pretty sure I have a good solid ground, perhaps not.. I put a meter on the coax connector at the swr meter end and had zero ohms to ground and no short to the center conductor. Is that good enough?
The reason that I went with a 3' is I wanted to be able to put my rig in the garage. I guess I'll have to make it detachable..?
07 Titanium loaded..
Current mods: scuba breathers, OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
bartt is offline   Reply With Quote
