Old 03-20-2008, 11:45 PM   #1 (permalink)
4rnr_paul
4rnr_paul's Avatar
Member Number: 17741
1995 4Runner Buildup
How I Got It
In December I bought a 1995 4Runner, AT, 4WD, V6. It was pretty much stock.
Stock FJ Alloys and Dueler Tires
First thing I did was get the stock wheels / tires off my brother's FJC and put them on my 4runner - much better than the tiny and very worn AT's that came on the 4runner.
Figure 1. The FJC stock alloys and dueler tires on my 4runner (and some lame-as$ FJ Cruiser in background ).
Upgrading to the OME Suspension
The stock suspension was changed out to an OME medium lift. I did this because I went wheeling a few times and my ride was much worse (more bouncy, more transmission of higher frequency bumps) than the FJ's. The OME lift included new front shocks, torsion bar (the '95 4runner doesn't have a coilover like the FJ), and steering stabilizer, and in the rear new shocks and coil. The lift adds about 2" over stock. The ride is now much more like the FJ:
Figure 2. The new front OME shock.
Figure 3. The new front OME torsion bar.
Figure 4. The new OME steering stabilizer.
Figure 5. Rear OME shock and spring.
Figure 6. Another view of the new OME shock and spring on the rear.
Figure 7. Wide angle view of rear suspension with truck on the lift.
Kaymar Rear Bumper / Tire Carrier
The stock spare tire location on the 4runner is under the rear end, which is a pain in the rear end to get at. I wanted to get the tire up on the rear door, and looked for tire carrier options. The Kaymar option came up because my brother is hoping one day to get one of these for his FJ - but Man-A-Fre had a 4runner bumper in stock. The bumper got installed at MAF at the same time as my OME suspension.
Figure 8. Kaymar bumper on the truck.
Figure 9. Another view of the Kaymar.
Figure 10. Tire swung out.
Figure 11. Tire swung out and close up.
Figure 12. Close up of the latch mechanism.
Figure 13. Bumper top is diamond plate steel. The bumper also contains duplicate brake, main, reverse, and indicator lights.
ProComp 16" 152's with BFG AT's
OK, these aren't my tires/wheels, but at 33.5" overall diameter, these look good on my truck, right? Actually, they're too big by about 1" and rub. Just a little bit smaller will do.
Figure 14. BFG AT's on black steel wheels.
Figure 15. More of the BFG's.
Super Swamper LTB's on 16" ProComp 87's
These are some more wheels/tires to be shared with the FJ. These tires are about the same overall diameter as the AT's, but they're thinner, which looks like they'll fit without so much rubbing.
Figure 16. Super Swamper LTB's on the 4runner.
Figure 17. Close up of the LTB chunky tread.
PIAA Front Lights
My 4runner came with some weak aftermarket lights on my front bumper. These were not good enough for night driving, but we won some lights at the Calico Cleanup, so I've changed them out. They're "Extreme White Plus Beam" driving lamps. They were donated to the raffle by Dirty Parts. Thanks!
Figure 18. PIAA's on the front.
Figure 19. Another PIAA shot.
4rnr_paul is offline   Reply With Quote
