Re: OK...What New Mig Welder Would You Buy???
I have the Lincoln 175 pak sold at Home Depot. Welds very well both flux core and gas. I use flux core outside and can weld up to 1/2" with a couple of passes and when I'm inside out of the wind, use a gas setup that helps to produce a much finer weld and can weld about 1/4" single pass with a beautiful weld. Welder is about $550, if you already have a tank, you're off and running. Otherwise, buy a filled tank for about $150 and you're set.
Mike
YinYang 2007 FJC They call me The Nukldragr!
