03-26-2008, 12:12 AM
#4 (permalink)
Member Number: 6623
Re: ARB Freezer solar power?
What about something like this: Coleman Solar Charger
CL-1200 Kit by ICP Solar
The "Power To Go" Kit
$139.99
COSTCO previously said:
Charge your batteries in your remote cabin, RV or during your camping trip. Perfect match for replacing the daily power consumption of 12V lighting systems and appliances such as coolers, small TV’s or laptops. Can also be used for charging small backup power systems.
Coleman Solar Charger:
Provides immediate charge when exposed to daylight, even on cloudy days.
Model CL-1200
Engineered to trickle charge 12V batteries, including automotive, deep cycle, traction, gel-cell, heavy-duty
Power: 1.2A, 15V (18W)
LED indicator lets you know panel is charging
Mounting screws included
Plug’n’Play® for quick connections, 10’ power cable, cigarette lighter adapter & battery clamps
Box includes:
o
(1) solar panel CL-1200
o
(1) 10’ Power extension cable
o
(1) cigarette lighter adapter
o
(1) battery clamp connector
o
(1) mounting screw set (4 screws)
(1) instruction manual
Weather proof
Dimensions: 38.9” x 14.1” x 0.91”
Weight: 10.6 lbs.
2-year warranty
Charge Controller (CC-4000):
Perfect match for solar panels generating up to 4A of charging current (12V).
Model: CC-4000
To avoid overcharging your batteries Perfect match for solar panels generating up to 4A of charging current (12V)
Intelligent PWM charge control ensures batteries reach max capacity
Nominal voltage: 12V
Max. solar panel current: 4A
Max. wire size: AWG 14 / 16 mm²
Temperature range: -15°C to +45°C (5°F to 113°F)
Box includes:
o
(1) charge controller CC-4000
o
* Case protection: IP20
Dimensions: 2.2” x 2.8” x 1.1”
Weight: 0.24 lbs.
* 2-year warranty
Sandoo Blue FJ
SoCal Events Calendar
