Re: vibration in 4x4 joystick
Don't worry about it. It's normal. when you start and stop the motor things move. The stick comes up through the floor and through a rubber seal. If things move that are solidly connected you will see the movement. You don't see the trans stick move because it is connected through a cable linkage system, but the 4wd stick comes up from the transfer case.
Although Nala is a 2wd, I have driven 4wd trucks at work for years. Everyone of them has had a 4wd stick that moved.
SF, A/T, Conv Pac,Aeroflow HLC's, Demello sliders, Demello Skid plate, OME 2" lift, BFG A/T, K&N filter, Magnaflow exhaust, KC 100 watt and 130 watt slim lights, Two tone air horn,Demello prerunner bumper, rear tow hitch,Allpro LCA's and Skids, Mile marker PE8000 winch, Amsteel blue winch rope, Delrin fairlead rollers, Demello 2wd tranny skid.
Treadlightly member.
