ruebarb previously said:
Is their a ground point back there or did you use the ground on the harness or tap a screw into the abundant metal around the wheel well?
There is a bolt that the harness is grounded to that I used. You need a pretty big "eye" type spade for the screw but it worked very well.
2007 FJCruiser Black ARB/WARN/IPF/OME
1988 4Runner ARB
