Old 04-05-2008, 09:04 AM   #510 (permalink)
BPSFJ
BPSFJ's Avatar
Member Number: 17886
Send a message via AIM to BPSFJ
Re: The Brotherhood/Sisterhood of the SANDSTORMS Thread
BOBTAILFJ previously said: View Post
How can I tell what the production date is for my SSFJC by looking at the VIN?
1. Position one represents the nation of origin, or the final point of assembly. For instance, cars made in the U.S. start with 1, Canada is 2, Mexico is 3, Japan is J, and Germany is W.
2. Position two tells you about the manufacturer. For example, A is for Audi, B is for BMW, L is for Lincoln and N is for Nissan.
3. This letter tells you about the make.
4. Positions four through eight tell you about the car, such as the series, body type, restraint system, and engine code.
5. Position nine is the check digit, a number from 0-9 or the letter X. By some magic finagling, law enforcement officials can detect if you've tampered with your VIN by this character.
6. Position 10 indicates the model year. The letters from B-X correspond to the model years starting with 1981, with X bringing up the rear with 2000; model years 2001 and up are indicated with numbers, starting with the number 1. There is no I, O, Q, U or Z. Confusing? Here's a list of the model years: B=81, C=82, D=83, E=84, F=85, G=86, H=87, J=88, K=89, L=90, M=91, N=92, P=93, R=94, S=95, T=96, V=97, W=98, X=99, Y=00, 1=01, 2=02, 3=03, 4=04, 5=05, 6=06.
7. The letter or number in position 11 indicates where the vehicle was assembled. For instance, 9 identifies that it was made in Detroit, Michigan.
8. The last 6 digits (positions 12 through 17) are the production sequence numbers.
Date of manufacture is on inside door jam upper right corner of the label.
08 SS 4wd
Tint, Alpine IVA-W205, Alpine Nav, JL 1000.1 amp, 2 JL 300/2, 2 JL 10w3v3, Wicked Fiberglass box, Morel Elate 9's , Quiet Coat and FatMat
AP Top Plate Rock Guards
Future MODS
FOX 3" Lift Fully Adj 2" ( All Parts are in just need to install)
AP Plate Top Rock Guards
Full skids
http://www.bigpicturesolutions.tv
BPSFJ is offline   Reply With Quote
