easelman previously said:
Ok I have what seems to be two radiators and I don't know why. One black one about 3/4" thick right in front of my bigger one. The front black radiator is about an inch or two smaller on all sides.
I also have a metal tube that angles down from the top right to the bottom left if you are facing the truck. I'll have to move it to put in my lucrum mount and winch (which I havent done yet). The winch is in but not plugged in.
Easelman, another very little-known fact to many folks here is that the main radiator contains the transmission oil cooler as well. It's embedded inside. When you pull the radiator you have two lines going in and two coming out.
