Re: Ok getting all of my fluids changed including the tranny.
I was amazed at how easy it is to change out the oil on the FJ, even more so now that mine is lifted. Rear diff is a joke as well, two plugs. One drainer, one filler. Haven't changed the transfer case or front diff since I don't switch it into 4wd often (even when I go off-roading I really don't need 4wd)
The things to remember: Before you drain the rear diff, make sure that you can get the fill plug out, if you drain it and then you can't get the fill plug out to fill it...you're screwed.
