» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 04-10-2008, 10:12 AM   #3 (permalink)
fj_tonka_toy09
Banned
Member Number: 15750
Re: Wire help and dash removal help please
The light green wires you are seeing are probably the reverse sensor wire and speed sensor wire. The reverse sensor wire probably goes to the left side of the dash. Try removing the fuse panel on the driver's side and see if you can see it. The speed sensor wire will be behind the glove box tapped into the ECU. I think it's a wire in like the second harness or so. You say your antenna is mounted on your dash, do you mean behind the speaker grille or behind the information pod? If you need help taking the dash apart, there are 2 screws under the silverdash trim pieces then they just pop out...move them slowly up. The plastic panel with the a/c controls will have 2 screws and pops out..it's easies to do it from the sides where the screw holes are. There will be 3 connectors you need to remove and then you'll have access to the radio. From there it's just taking out the 4 radio bolts and unhooking your harnesses. They are plug and play so it should be pretty simple. I don't see a picture so let me know if you need anymore help.
fj_tonka_toy09 is offline   Reply With Quote
