Re: pro comp series 87 wheel ?
Layonn,
I have the series 87 wheel in a 4.5 inch backspace and am running 255/85-16s. I think you'll be okay with your body mount chopped from a rubbing standpoint. As far as the caliper is concerned you have no worries. I might be mistaken but the 4.25" BS should help you from a rubbing standpoint as opposed to the 4.5" like I'm running. Better yet, would probably be wheeler's 4 inch BS. Somebody, please correct me if I'm backwards here.
Painted headlight bezel, Series 87 steelies with 255/85-16 Maxxis Bighorns, BMC, ARB full length rack, 60" hi-lift, OME Heavies on all 4 corners, Budbuilts front to back, OEM sliders, Scuba Driver mods, Upper and Lower rear Digger Links, TRD CAI, All-Pro High Clearance tailpipe, Custom Built Rear Shelf, Hacked Rear Diff Lock, VSC on-off switch, Custom Expedition One Front Bumper, EPi 9000lb winch with synthetic line, and lots of manual recovery gear and tools.
