We have the first order of these in stock!
Prices are as follows:
1 to 9 sets = $499.99 a set
10 to 20 sets = $459.99 a set
over 20 sets = $399.99 a set
Please post here if you are willing to commit; I will add to the list to keep track of where we are at for 30 days.
THIS GROUP BUY HAS BEEN EXTENDED UNTIL 5-30-08!
Tacoma's, FJ's, and 4Runner's run out of factory adjustment when you install lift kits. With our patent pending design this upper control arm provides an additional ±2 degree of caster and 0 degree to +5 degree of camber change. Built with an OE style ball joint and bushings, this arm is designed to correct alignment angles while maintaining factory ride quality. The hybrid tubular and forged steel design is tough enough to race - on or off-road. These remove and replace arms are available in pairs for lifted and off-road applications or individual left and right arms if just one corner needs adjustment.
Adjustment range: Camber 0.0 degree to +5.00 degree Caster ±2.00 degree
Installation time: .8 hr/side
Required: 25470, 25480 - includes Left and Right arms 1 per axle
Required: 25472, 25482 - includes 1 right arm ONLY 1 per axle
Required: 25473, 25483 - includes 1 left arm ONLY 1 per axle
25470, 25472 & 25473 Applications
Toyota 4x4: 2005 & Up Tacoma
Toyota 4x2: 2005 & Up PreRunner
25480, 25482 & 25483 Applications
Toyota 4x4: 2007 & Up FJ, 2003 & Up 4Runner
Toyota 4x2: 2003 & Up 4Runner
Patent Pending
SPC Application Search - Product
