Old 04-14-2008, 11:21 AM   #3 (permalink)
SVTim
Member Number: 14671
Re: Drive shaft lube - too much grease, whoops.
I've never done this, so if I am wrong, somebody correct me.
I think you need to removed the drive shaft from the propeller shaft, there are 4 bolts. Then slide the drive shaft out, clean up the mess, reassemble. Torque the 4 propeller shaft bolts to 65 lbs/ft. Put 3 or 4 pumps of grease in there.
2007 VooDoo Blue / 5AT / 4WD
Rear Diff Hack (Works in 2HI & 4HI) / Rear Diff + ATrac Hack
Rough Country 3" Lift
KU4IY (Yaesu FT-7800)
SVTim is offline   Reply With Quote
