Yes this is true. They will be here soon. This will allow the front gears on FJ's with Automatic to be changed without replacing the carrier.
Package deals:
4.56 Front and rear Ring & Pinion sets, STD installation kits including pinion seals, crush sleeves, nuts, shims, loctite, marking compound, front side/stub axle seals, rear pinion flange/adapter
everything needed to change to 4.56 gears.
$719w/ std kits (for low
mileage trucks)
$1099 w/ master kits (w/o rear locker)
$1139 w/ master kits (w/ rear locker)
Front gears alone run $299
If you have 3.73's in your vehicle now it is not necessary to change front carrier as the 4.56 gears are a special "THICK" gear to fit on 3.73 carrier:
add ARB Air Locker (call for pricing this way)
carl@justdifferentials.com
509-888-AXLE(2953)
If interested please call or email. We dont check this forum everyday
