Re: Using factory jack with a lift???
Your rear will be fine. But changing a tire in the FRONT will be a trick.
I use a 4x4 (or 2 2x4's stacked), but haven't done so since my OME+Toytec fronts were installed.
I'll let you know if a 4x4 block is enough. Should be if my math works out. (That-is 3.5" lift over stock...3.5" block of wood under stock jack. YES!)
-MK-
07 TRD 5AT
Wired Passport | Wired Garmin | Smoked Headlight Covers | 3M ClearBra | Fancy Batt Clamp | Disabled DRL | 3M Window Tint | ToyTec
FJ3-FRCC 3" Lift | Cornfed 1" Rear Spacer | BDS Rear Shocks | 08 Side Visors | Lucrum Winch Mount
