Old 04-15-2008, 10:15 AM   #9 (permalink)
sonof40
sonof40's Avatar
Member Number: 11473
Re: Drive shaft lube - too much grease, whoops.
FJ_Kayaker previously said: View Post
Done!
Thanks for the help everyone.
I removed the 4 nuts holding the drive shaft to the t-case output. I was able to compress the slip yoke about .5 inches not enough to remove it from the bolts so I removed the zerk fitting and that gave the grease someplace to go. I compressed the slip yoke all the way by hand and it squeezed all my grease and then some out of the zerk fitting hole. I didn't have to seperate anything. Put it all back together (properly torqued) gave one squirt of grease and am calling it good. thanks again.
Thanks for sharing all that. Good stuff to know.
Steve
TLCA
Sleeping/Storage build: http://tinyurl.com/367bbw
CB: Cobra 75 / Bandi http://picasaweb.google.com/steven4m/CBInstall
Back Door Inside Latch: http://tinyurl.com/2jxwkk
sonof40 is offline   Reply With Quote
