Re: A/C refrigerant
Make sure you get it evacuated before filling(evacuating removes most air and water form the system). Did any oil leak out? There is oil in the compressor and in the system (both are seperate). If you do not get it evacuated, and there is water in the system (usually from humidity in the air) the A/C will not cool well, and could freeze up at the expansion valve.
