Old 04-17-2008, 03:18 PM   #6 (permalink)
BMThiker
BMThiker's Avatar
Member Number: 3667
Re: Viair system mounting--please help me decide
more pics
All the electrical stuff I mounted to a sheet of alum that I screwed down to the firewall flange. Since these pics were taken, I have installed a different check valve and moved the pressure switch to the other side of the compressor's manifold. I also added an indash switch to control power to the compressor.
I ran the airline from the engine compartment along the top of the passenger side frame rail, then up into the compartment below the subwoofer thru a rubber grommet already there. Across the back of the rear cargo door sill (parallel to the rear window washer fluid line). Then into the compartment where the bottle jack is and out the rear door hinge rubber boot.
line runs up the gap between the door and body with no pinching and connects to the driver side tank.
All-Pro bumper, USB links, IFS skid, Extreme LCA links, LCA skids & Bandi mount
Bud Built trans skid/crossmember/gas skid
Metal-Tech red sliders
OME 886/895 springs & shocks
Super Swamper 34" LTBs
Warn 9.5xp/Masterpull line
Demello rear bumper
My PhotoBucket
TLCA #16667 Ga Cruisers - Black Sheep Upstate Cruisers - Safety Officer
Things are more like they are now than they have ever been. ~ Gerald Ford
BMThiker is offline   Reply With Quote
