Re: RC6 and extreme CV angles
Not to mention a higher center of gravity with the same ground clearance as a good set of adjustable coilovers. IMO I like the look of the 6, plus you can run a couple inches bigger tires, but unless you go straight front axle, it doesn't make much wheelin sence.
Ligten up, it's the internet!
air previously said:
Quote from: BigDouggieDoug
You Should Help Chris Walk
