Re: Fog Light / Driving Light Wiring Help
The only problem is if you hook up the relays to the low beam and the highbeams separately, the fogs will turn off when you turn on your highbeams and the driving lights will go on.
what I did was to have both ARB fogs and Driving lights on separate OEM Lighted switches, but have the trigger power not from the low/high beams but from the ACC ON fuse connection, so I can have either light on when I want, but when the ACC is off (turn off the car) the lights go out and I don't have to worry about forgetting to turn off the lights.
T
TLC #17889
In service: March 25th, 2006
ARB Front Bumper, GOBI Stealth, Dirty Part's 2nd Battery Kit, Original Bandi Mount #11, OME 883, ARB Fridge, FJoel Battery Clamp
