Old 04-25-2008, 09:31 AM   #2 (permalink)
Regud
Regud's Avatar
Member Number: 14560
Re: Toytec 1/2" top spacer TP14
Yes, it fixed the lean after installing OME 883 springs.
Yes, the stock studs were long enough.
Like others have posted here in the past, it is hard to notice the lean (OME 883 w/o tp-14 spacer) without measuring both sides. However, I like to know that things are level and square, so I installed the spacer.
Blaise previously said: View Post
For those of you running it on the driver's side to fix the FJ cruiser lean, has it worked for you?
Were the stock studs long enough or did you have to get longer ones?
'07 Sun Fusion, Trail Gear Sliders, OME 883, painted Alloys, SAS Scanguage II Maplight, SAS Fog Light kit, A-TRAC, AFE CAI, URD Y-Pipe
Regud is offline   Reply With Quote
