Old 04-27-2008, 06:15 AM   #8 (permalink)
RoseCityCzar
RoseCityCzar's Avatar
Member Number: 12511
Re: Rear bump stops oem part #???
The Stig previously said: View Post
Wouldn't the bags expand into the space with enough pressure?
what happens if you just give the airbags lots of pressure when theres no load on the fj. does it lift up?
You can lift the FJ around 2" with the max pressure 35 lbs. But without the weight of the trailer or heavy load in the back the ride is verrrry stiff.
Even at the 5psi minimum I believe there is a somewhat stiffer
ride.
I have installed the front coilvers and tires and wheels(285/70-17 bfg mud km2 and american eagle 137 series rims) and like the look without adding 2" in the rear . Think I'll adjust the front for level and try that fo a while. That would keep the front suspension more centered in it's travel range at rest and for the type of off roading I see myself doing may be just the ticket.
Larry
RoseCityCzar is offline   Reply With Quote
