Old 04-22-2008, 09:27 PM   #9 (permalink)
Runt
Runt's Avatar
Member Number: 10685
REAR CARGO STORAGE SOLUTIONS: Compilation of different members' builds
To read the original full thread and post questions/comments on this topic, please go to Rear FJ utility box with built-in sleeping platform
The idea of this box came from LandCruiserSteve’s design of his original “Box”. This one is basically a single storage box that has a space under the roll out drawer for the sleeping platform to fold up and be stored in. Does not require removal of the back seat. Basically butts right up to the back seats when they are folded up. Uses similar hardware as Steve’s original “Box”. It has two storage trays. One behind the roll out (will accommodate a rifle with a 20” barrel or air compressor) and one inside the rear of the roll out (will accommodate a pistol grip shot gun or tire chains). The sleeping trays fold into each other via a piano hinge (one is slightly smaller than the other). The legs unscrew from the pipe flange base and store within the tray when it is closed. The top lid of the storage box then opens from the top via another piano hinge, drawer rolls out and the platform then slides under the roll out for storage. When used as a sleeping platform the two trays have a reinforcing steel plate on the interior/bottom sides. This plate spans the gap between the two trays where the piano hinge to add rigidity. All materials are made out of 12 gauge (1/8) alum. All trays/sleeping platforms are formed boxes built with a press for strength. Roll out slides are rated for 300 lbs and lock. Top surface will be checker plate for traction and the rest is smooth alum, all will be painted gray to match the interior. Calculated weight is around 96 lbs. Construction starts this weekend. Locking mechanism is the only thing left to figure out. So far I’m leaning towards a simple padlocks. Thoughts appreciated
Ok we got started on it today. About 3/4's of the way there. Still need to add the dividers in the roll out, finish the trim on the front of the roll out to cover up the gaps, rivet in the piano hinge, and fab up the sleeping platform etc. After all is said and done I put all the materials on the scale & the box with sleeping platform weighed in at 101 lbs. Decided to go with 12 gauge smooth aluminum for everything. 300 lb locking drawers so there is zero shake or movement. The interior will be lined with ¼” high density foam. The box will be silent. You can see the blue tab that locks and unlocks the drawer. Kind of a nifty slider, it locks half way as well if you want. The locking mechanism is still leaning towards a simple padlock type set up. Unless any one has a better idea? Turned out to have 6’4” of sleeping surface. The extra weight in the back is exactly what the OME Heavies needed. Any way I should have more pics coming up once it finished. Maybe Wednesday. Here is were it's at for now:
What it will look like open:
You can see the locking mechanism blue tab on the right side of the roll out:
Here is a example how it would store a 20" barrelled rifle (extra room is for foam):
My box measurements were made with seats pushed fully forward, bottoms removed, seat backs laid fully forward and a air mattress in the back which puts you level with were the seat bottoms would have protruded into your sleeping area. You then get about four more inches of head room.
I'm restricted to steel or aluminum, plywood is nice but you lose the interior space and I'm worried about the legalities. It's tough to build a box that is secure but yet light. One big reason why I went with 1/8th formed alum. over plywood. Just enough room for ammo box, 20" rifle or air compressor etc. My experience with plywood is poor. On my old BJ42 Land Cruiser I built a plywood box (I used the best 3/4" 100 % Douglas Fir...yes it was a long wait to get it) with wood screws nails etc....basically a way overbuilt box and with four tire chains bouncing around it came apart. It took years of beating but after time it fell apart. This may of been because it had no top a lot of the time and moisture weekend it, but for the price of plywood these days alum. was my choice. In my opinion if you want to carry tire chains 12 months out of the year (and I do) you need steel or alum. Simply because they bounce & beat the s$&t out of your box. My old plywood box had high density foam glued to the top, bottom & sides which was not very noisy but the logging roads and the bounce took its toll on the box.
Lots of mods....see build thread: http://www.fjcruiserforums.com/forum...nt-mobile.html
It's a good life...if you don't weaken !
Runt is offline
