Old 04-27-2008, 02:23 PM   #12 (permalink)
layonnn
layonnn's Avatar
Member Number: 10006
Re: Installed Fitch Fuel Catalyst
alas.babylon previously said: View Post
What do you think is in the container to perform the cataylist? Perhaps mothballs?
Yes, mothballs will slightly assist the octane rating of gasoline. HOWEVER, in
that grain of truth there lurks the potential for disaster. One must use very
few mothballs (naphthalene only) because the ratio of carbon to hydrogen in
the molecules makes for a very dirty burning fuel. Too many mothballs and your
engine will load up with carbon deposits -- very bad news in the performance
department.
Also DO NOT mistakenly use moth crystals (paradichlorobenzene). The chlorine
atoms in this material becomes HCl upon combustion. Hydrochloric acid (HCl) is
very destructive to engine internals.
Finally, unless your engine is high compression and in need of high octane
fuel, enhancing the octane rating of the fuel over what is required is simply
a waste of money. High octane fuel burned in an engine designed for lower
octane fuel does not increase engine power.
If they just threw some mothballs in a canister and put hose fittings on it then they are making a ton of money.
Layton
2007 Voodoo5AT 4x4
TRD Supercharger arrives Friday!
"God forgives...rocks don't"
layonnn is offline   Reply With Quote
