calijetfxr previously said:
Thanks for all of your replies. As far as a 6" lift not giving any advantages over a 3" lift with anything smaller than 33s, with all due respect, I believe this to be an incorect statement. You would be correct that you don't gain any advantage at the diferentials but measure the distance to your sliders and you will gain clearance. I've always runa 3 inch lift in the past and while very practicle, I would often wind up hung up on my belly skids or sliders when wheeling (over a berm for example). A 6" lift would help to alleviate that type of situation with or without the larger tires. Or I could just pick a better line... Thanks again for all your responses.
The clearance issue is with the front cross member. It just sticks out down in front now with no skidplate. You'll have to get a custom skid made since there are currently none offered nor compatible with a 6" lift.
