FJ4RWS previously said:
The stock Toyota bolts are grade 8.8 which is roughly the same as SAE grade 5. SAE grade 8 is metric 10.9. Either grade in a bolt washer combo instead of a flanged bolt is OK. Just make sure that the washers are also the same grade as the bolts and use locktite.
Yup, I'm using bolts and washers from Metal Tech. cor you can check harbour freight or tractor supply online.
