Re: OK guys need advice on the TRD air filters....the good, the bad, the ugly
survivorman previously said:
OK guys and gals, I have the TRD air filter and have been doing some searching.....I was going to buy the cleaning kit, but wanted to hold off and get a few opinions on these.....are they worth the money?? do they help with increasing MPG?
I have seen where some people were having issues with the MAF sensors....is this from over oiling?? do you guys recommend another filter? stick to the generic OEM filters?
I dont know if I want to be sitting around trying to oil a filter, especially if there is no real benefit.......so keep the filter and buy the cleaning kit? screw the TRD filter and use the regular OEM filters with no oil needed OR Use another filter?
also how much oil do you guys put on these things? do you spray the oil on BOTH sides of the filters?
thanks for any advice or experience given..
I purchased the K&N drop in type OME from the dealership. I also purchased the regular replacement so when I wash clean, air dry and oil The K&N I can drive with the new OME. It's real easy and I like to keep my engine breathing clean air with low restriction! I wash it every oil change 3k and it collects alot of the finer particles. Just spray a little amount of oil to the outside of the filter the side the air is flowing in from. It will absorb in, just don't get tempted to smother it or you will set of the sensor. I felt the trottle response when I removed the stock unit the first time and replaced with the K&N so yes milege and HP improved just a little!
6" Fab Tech Lift, Bushwackers, 20" BBS wheels Nitto Terra Grappler 325/60/20 All Terrain tires. Spyder Trax 1.25 spacers Scuba mod, Manik tail light guards, Hunter GT807 full brush guard, Predator step bars, diamond plate interior trim, dual cd's, leather seats, Toyota Trail Team Badge.
