Need some help setting up new stuff
I just got a new FJ and need some help wiring up some electrical stuff.
Ive got the following things to power
Viair 380c compressor
Cobra 75 WXST radio
Alpine class D amp (cant remember the model but its 400w @4ohm)
LED emergency lights front and rear
I want the compressor and CB to only run when the key is on. What can I hook to for that signal? The compressor is also for a set of air horns so how do I hook that into the stock horn switch? I thought about the Blue Marine power block but I dont know how much it can run. The lights are about 12 amps max. I plan on taking the amp power on from the stock sub switch.
Basically I dont know what needs to go straight off the battery and what could go off a power block. I wanna keep this neat and not look like a rats nest of wires going all over. All Ive ever done before now is simple single amp installs.
Bart & Julie-Life Saving Firefighting Off-Roading Fools
"Me thinks the world is crazy save thee and me, and at times I wonder about thee." Samuel Johnson, 18th century English writer
"There is a knowledge curve in EMS. You start out at knowing nothing, go to knowing something, progress to knowing a lot, maybe come close to thinking you know everything, and then slowly start to slide down as you realize more and more you know less and less of what you thought you knew. And that is probably the place you want to end up. -Street Watch
'08 Trail Team 6spd w/Icon/URD Shifter/Viair 380c/Train Horn/Doug Thorley Y-Pipe/Full Amsoil Fluid Swap/Spidertrax/Trail Gear Sliders
