oldcop041 previously said:
Good idea, but I checked it and I do have power to the switch. Not sure of how many volts - my meter is down - just using a test light. Showld be 12V though if I am getting power.
Check all the connections on the relay. Power (verify at the relay with test light) as well as GND (using the test light in the opposite sense, applying 12V to it and grounding it on the 85 terminal) and the feed.
Sounds like you've eliminated your switch, I wouldn't put it past a bad relay or bad connection somewhere.
