Old 05-01-2008, 10:50 AM   #9 (permalink)
doublejfj
doublejfj's Avatar
Member Number: 17287
Re: alternator and voltage regulator question
So what I'm wondering is if you have almost no load and a very good battery, will the alternator back off the voltage because there isn't any demand? It certainly appears to be doing that.
Hmm... It may have to do with this, which I had in an old link under "automotive" in my browser:
The sensor for the regulator is usually connected to the positive post of the battery and when it senses a low voltage condition, allows more energy to flow in the rotor coil, creating more energy in the stator coils. It does this through a series of points, raising the points off of the contacts to allow less current to flow, or dropping points onto the contacts to increase current flow.
If you think about it, it could be preset to something like 13V and the 13.2V is still not registering as a "low voltage condition."
When the car starts, if it's at 12.8 or something, the charging circuit is going to kick into high gear and maybe charge it back up to a preset 13.8V and kick back off again.
Here's an idea: Before you start your FJ next time, see what the battery reading is. Report back and we'll see if this theory has any merit.
J+J+FJ - '08 Titanium MT6 - Not stock, pinstriped paintjob.
Finally, our integrated USB chargers are here!
IP68 cable glands for roof rack wiring!
Tell us why you deserve a FREE Quad USB charger
doublejfj is offline   Reply With Quote
