Old 05-04-2008, 07:47 AM   #2 (permalink)
LandCruiserSteve
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Re: Driver side door electric lock works intermittently
It could either be the switch itself or the solenoid that activates the door lock mechanism. However, assuming your passenger side switch works fine, it's likely the switch. You might try swapping the two switches to see if that's the case.
And, it might just be a loose connection between the switch and the harness plug.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline   Reply With Quote
