Thread: CV boot
Old 05-06-2008, 09:22 AM   #11 (permalink)
BigEd78
BigEd78's Avatar
Member Number: 17439
Re: CV boot
gon2srf previously said: View Post
Which boot, inner or outer? The inner boot is a soft rubber, the outer boot is more of a plasticey material and tends to tear easily. You could try gently grabbing on one of the ribs of the boot with needle nose pliers and tug on the indention, however unless you think the boot is actually rubbing on the axle I would just leave it alone. I'm still curious why you took it in, in the first place?
The seal on the front driver side axle is leaking. They are going to cover it under warranty. It is the outer next to the tire. I dont think that it is rubbing anything. I think that I'm going to leave it alone until I put the lift on then fix it then since I will already have the tire and most of the front disassembled anyway. It almost looks like it is twisted.
-Edward-
If it aint broke fix it till it is.
BigEd78 is offline   Reply With Quote
