Thread: CV boot
Old 05-06-2008, 10:52 AM   #12 (permalink)
gon2srf
gon2srf's Avatar
Member Number: 6131
Re: CV boot
BigEd78 previously said: View Post
The seal on the front driver side axle is leaking. They are going to cover it under warranty. It is the outer next to the tire. I dont think that it is rubbing anything. I think that I'm going to leave it alone until I put the lift on then fix it then since I will already have the tire and most of the front disassembled anyway. It almost looks like it is twisted.
Ed-
Elaborate just a little. You say a seal is leaking, what seal, the outer wheel bearing seal? Or do you mean the boot is leaking? You say the dealer is covering this seal under warranty but they are not going to fix the boot or you just don't want to be bothered and plan to fix it yourself when you install your lift?
Since you think the boot is twisted have you tried twisting it back? If you can do that then the clamps need to be tightened afterward if possible or replaced.
If the dealer is going to warranty the complete fix then get it done. Replacing a boot is a much tougher job than you can imagine and requires several specialty tools to top it off. The whole axle must be removed just to replace the inner or outer boot. Installing your lift is as easy as removing the tie rod and pulling the old strut assembly. The axle removal is a lot more involved.
Good luck.
TLCA#16768
33' BFG MUD's, Icon Front Coil Overs, OME Rear Shocks and Coils. ARB Bumper, Warn 9500XD winch, MAF Sliders & Skid Plates, Gobi Ranger Rack w/ PIAA Lights ft, rr, sd, w/Gobi Hi Lift, axe and shovel Mounts, dust lights. Dirty Parts Dual Battery System, Cobra 75 WX ST CB, Extreme Hi Lift Jack, Power Tank 10 lbs. CO2 System, All Pro HD LCA's, Custom Rear Drawers. Custom electrical.
Emerald Pacific Financial
949 235-1494
gon2srf is online now   Reply With Quote
