Old 05-07-2008, 05:45 PM   #2 (permalink)
marcus21x
Member Number: 19605
Re: Which is better?
Speaker level inputs for one reason in particular, the aftermarket high to low adapters tend to be noisy(hiss and such) for a sub it will work good enough but for high level i wouldn't recommend it, and from dealing with this on a day to day basis this is what i have found.
If your amp has it, use it. Also if it is going to be running a sub, i would also recommend running your signal of the fronts instead(doors not dash)...
marcus21x is offline   Reply With Quote
