Re: Auto tranny acting wierd down hills.
RoverGGM previously said:
Yes, just like the Brick pilot stated, the transmission is controlled by software called "Grade Logic".
To reduce gear "hunting" and unnecessary shifting, Grade Logic Control and Shift Hold Control systems are integrated into the shift programming of FJ automatic transmissions. Grade Logic Control alters the 5-speed automatic's shift schedule, reducing shift frequency while traveling uphill or downhill. Using inputs monitoring throttle position, vehicle speed and acceleration/deceleration, Grade Logic compares the operating parameters with a digital map stored in the transmission computer. When the system determines the FJ is on a hill, the shift schedule is adjusted to automatically hold the transmission in a lower gear for better climbing power or increased downhill engine braking.
Shift Hold Control prevents upshifts to higher gears (fourth and fifth) in repeated winding-road situations where the throttle is quickly released and the brakes are applied. This reduces disturbance to the chassis when entering a corner, and ensures strong power is available without a downshift. Shift Hold Control improves throttle responsiveness and reduces unnecessary shifting on curving roads.
Never knew that good info. So i guess i should only worry if it starts to slip.
Mods:
TRD CAI
TRD cat-back exhaust
Tinted front widows
Cobra (75WXST) 3' Firestik.
Piaa 520 Driving lights.
Total chaos skids.
Rain guards.
3 inch OME lift
MY BUILD IS DONE.
