Old 05-09-2008, 05:51 AM   #2 (permalink)
RoverGGM
RoverGGM's Avatar
Member Number: 471
Re: Funny noise/feeling from Brakes?
This is not an issue that requires attention, it's a normal effect of the type of braking system on the FJ.
The braking system is highly pressurized, to allow the system's ATRAC and the other traction enhancement systems to work properly. There is an electric pump mounted next to the brake master cylinder that pressurizes the unit when you first start it or sometimes after/during a brake application. It will activate whenever the pressure in the reservoir drops below a certain level.
Pump you brakes a few times with the engine idling and you will hear it activating to re-pressurize after a couple presses of your brake pedal.
Women and cats will do as they please,
men and dogs should relax and get used to the idea
Robert A. Heinlein
RoverGGM is online now   Reply With Quote
