Old 05-10-2008, 09:36 PM   #7 (permalink)
JonB
JonB's Avatar
Member Number: 2515
Re: All Pro FOX 2.5 issue's
As far as the reservoir mounts go it sounds like you have them mounted on the wrong side. Swap sides from the driver side to the passenger side.
You can't measure lift until after you have driven the vechicle, they come pre set at about 2.5" of lift, you can crank in more if desired. The front springs are Eibach 600#.
JonB
http://www.allprooffroad.com
JonB is offline   Reply With Quote
