Re: Firestik Antenna and other pieces and parts
Hope you don't mind my suggestion, but you might want to hold on to that equipment. As a HAM operator I've learned the hard way about holding onto coax cable, antennas and mounts. Same goes for CB setups.
The antenna could always be used as a back-up should something happen to the one you're using now.
The coax can be used for repairs, jumpers or future installs - you cut off the 'ring' on the end and use the cable accordingly. Put on a PL-259 connector and you have a jumper/new antenna wire. Who know, you may get your HAM license and have a need for the cable as well.
Good luck!
73, de
Mike
Freedom isn't free...thank you Veterans!
